Activity Forums Blackmagic Design Is there still a problem with PAL DV output
  • Is there still a problem with PAL DV output
    Posted by Jonathan White on August 11, 2005 at 12:18 am
    Got the latest DL Extreme drivers and latest version of FCP 5 and while the problem with PAL DV is not as noticeable as it used to be there’s still a problem. I’m getting a slight flickering line at the top of the screen (it’s only visible in 16:9 anamorphic as normally it would be hidden..
    The only way I can get around it is to crop down one line..
    Is it just me or is this a reognised issue?
    Johnny White
    Yves De muyter replied 21 years ago 4 Members · 7 Replies
  • 7 Replies
  • Roddy Jamieson
    August 11, 2005 at 8:06 am
    Sounds like the deck blanking, I had this on my DSR1500. I adjusted this in the menu and switched off the 16:9 detect on the deck. The flicker is possibly the 16:9 ident on the tape or timecode info.
    Roddy Jamieson
  • Jonathan White
    August 11, 2005 at 10:33 am
    Thanks for the response.
    The problem is it still seems to exist when outputting directly to a monitor?
    I noticed it seems to switch on and off as I pause and play from the timeline (the top line seems to split and the whole picture moves down a line on commencing playback)
    Does this make sense?
    Johnny
  • Carsten Orlt
    August 11, 2005 at 11:50 am
    Hi Johnny
    I have a Pipe (sorry to intrude guys, but one has to see what the competition is doing 🙂
    and I saw kind of the same problem. After some tremendous help from the Aurora guys I finally got the answer back.
    FCP is doing it! Apple decided to make all PAL (regardless of DV or any other codec) upper first for external playback. As you know PAL DV is lower per spec. So Apple now forces FCP (external vout only – effecting all cards) to throw away the first line, shift all the rest one line up and filling the last line with black. This makes PAL DV on the external vout effectivly upper first. It doesn’t effect the processing because it really is only a ‘playback to output device’ adjustment. If you would output through Firewire to a DV deck all would be normal.
    The reason you see a change is when you stop is that when paused FCP displays the ‘normal’ frame
    That’s how I understood it anyway. Not a techo you know…
    Who would have thought.
    Cofe
  • Roddy Jamieson
    August 11, 2005 at 2:04 pm
    What are you playing back on?
    Roddy Jamieson
  • Jonathan White
    August 12, 2005 at 8:58 am
    Playback is 8 bit uncompressed output through a decklink extreme on SDI directly to a JVC monitor.
    Maybe I need to shift the whole output by a line….
    Johnny
  • Yves De muyter
    August 12, 2005 at 11:43 am
    Avid is doing just the same. DV in upper field. Drop the spec: make a system that actually works.
    At *least* enable users, when they create their own preset, and setup DV upperfield, make it upperfield……….
    -Yves
  • Yves De muyter
    August 19, 2005 at 5:05 pm
    OK,
    In adobe premiere to make your lowerfields videoclip upperfield without shifting up and rerender:
    Right click the clip in the timeline.
    Enable “Reverse field dominance”.
    AND VERY IMPORTANT: Check “Interlace Consecutive Frames”
    I have no clue what the’ve changed in 5.1.1 regarding the fields problem…
    -Yves
