Activity Forums Adobe After Effects Is there some quick way to achieve this effect?
  • Is there some quick way to achieve this effect?
    Posted by Levan Khomeriki on June 12, 2015 at 11:07 pm
    So, I’m trying to achieve this effect, but can’t figure out how can I make this “inner” part follow outer layers.
    https://vimeo.com/84591631
    Is there some way to quickly do it?
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Levan Khomeriki replied 11 years, 3 months ago 2 Members · 2 Replies
  • Derek Boettcher
    June 13, 2015 at 4:48 am
    Make your shape layers the size you need, and position them where you want them at the end, parent their position properties with their cut outs. Then make a shape layer the reverse of the bottom portion of your cutout and make that an alpha matte to your inner shape layer.
    Best,
    Derek Boettcher
    Creative Management
    BTH Media Group
    https://bthmedia.com
  • Levan Khomeriki
    June 13, 2015 at 8:40 am
    Derek,
    thanks for the reply.
    Could you just clarify a little, what you meant by ‘make a shape layer the reverse of the bottom portion of your cutout’?
    Thanks again
