Well the difference is that you can set a different preview resolution for just the RAM preview in the preview panel if you want to work in a higher res in the comp window.
Oh I’m clear about that now. Res in Preview Panel for render depending on the quality you’ve set but Res in Comp Viewer is the quality of how you see things in the comp viewer. got it! thanks!
