Activity Forums VEGAS Pro Is there ‘lossless codec’ in Vegas 6?
  • Is there ‘lossless codec’ in Vegas 6?
    Posted by Jake Zeer on January 28, 2008 at 6:01 pm
    Can someone tell me if there is an encoding option of using a ‘lossless codec’ like in Avid or a ‘same as source’ codec – in Vegas 6 or the recent version of Vegas.
    Jake Zeer
    Jerry Waters replied 18 years, 7 months ago 4 Members · 6 Replies
  • Laszlo Kovacs
    January 28, 2008 at 6:19 pm
    Yes.
    You can render uncompressed, that’s absolutely losless.
    If you want some compression, but it must be losless, google for huffyuv, it’s a losless codec.
    In theory DV is not losless, but Vegas handles it in a way, so that it is practically losless. If you re-render a video, the untouched frames are just copied, and only the altered frames are really rendered (where you applied some effects, transitions, etc.).
    I’m unaware of a “same as source” option in Vegas – I would say there isn’t any, but I may miss something…
    Regards
    K.L.
  • Jake Zeer
    January 28, 2008 at 6:46 pm
    Where do I select this option? I see uncompressed Audio but i don’t see uncompressed Video.
  • Laszlo Kovacs
    January 28, 2008 at 7:12 pm
    File/Render As…
    Choose filetype AVI.
    There’s a default template (uncompressed).
    Press “custom” and check the settings wether they’re OK for you (audio settings, rendering quality, etc…)
    Regards
    K.L.
  • Earle Del rosario
    January 29, 2008 at 2:55 am
    I hear that Cineform.com is okay for lossless codec.
  • Earle Del rosario
    January 29, 2008 at 2:41 pm
    Correction: That was the first impression I got of Cineform. I’m not certain if whether Cineform allows for minimal compression at render, or if it is only used for streamlining formats for minimal compression at capture for the timeline.
  • Jerry Waters
    January 31, 2008 at 4:17 am
    Cineform is described as “virtually lossless” and it is. I’ve done several rerender without noticeable change. The higher the product of theirs you are using, the more renders you can do.
    JerryW
