Activity › Forums › Apple Final Cut Pro › Is there is ‘copy clip attributes’ in FCPX?
  • Moira Elefson
    April 22, 2012 at 5:52 am
    When you select a clip and press command-c or Edit/Copy to copy the clip you’re simultaneously copying the effects and attributes for the clip as well. Simply select the other clip you’d like to paste the attributes to and then from the Edit menu select Paste Effects, or press command-option-v on your keyboard.
  • Olly Lawer
    April 22, 2012 at 9:44 am
    Ah, brilliant. Big help. Thanks.
    One last thing. How do you adjust and resave a colour preset once you’ve set it up?
    Olly Lawer
  • Alban Egger
    April 22, 2012 at 4:48 pm
    Just type in the same name to replace the Preset.
  • Jason Porthouse
    April 23, 2012 at 1:12 pm
    Bear in mind that pasting attributes pastes ALL attributes – you can’t choose which to paste as you could in legacy FCP. At least removing the unwanted attributes is easier with the inspector pane. PITA I know, and I hope that Apple will be forthcoming in changing this.
    HTH
    Jason
    _________________________________
    Before you criticise a man, walk a mile in his shoes.
    Then when you do criticise him, you’ll be a mile away. And have his shoes.
    *the artist formally known as Jaymags*
  • Olly Lawer
    April 24, 2012 at 10:53 am
    Thanks. Appreciated.
    Pain only copies all attributes, but I guess you can pick and choose in the info pannel so they saw no need for an extra step.
    Olly Lawer
