Activity Forums Adobe After Effects Is there anyway to change the size of a composition and everything within it?
  • Is there anyway to change the size of a composition and everything within it?
    Posted by Daniel Haskett on February 21, 2006 at 3:39 pm
    Hi there
    Basically, I have made an animation in a composition that is about 1000×1000 and I want to put into a PAL DV 520×768 format. When I change the size of the composition obviously it crops everything within. But when I try and rescale all the objects within it the animation gets messed up. I think its because certain objects are parented to each other….would that be why? Like arms and legs are out of place.
    So is there anyway I can resize it all? Like in Photoshop you have image size and canvas size…? I know I can precompose and put it into a new composition but then I have to edit it in the other composition….
    Thanks in advance!
    Dan
    Sam Moulton replied 20 years, 6 months ago 3 Members · 4 Replies
  • Steve Roberts
    February 21, 2006 at 3:48 pm
    If you don’t want to precompose, you can try parenting the parent layers to a new null, then scale down that new null. It would be sort of a “grandparent” null.
  • Daniel Haskett
    February 21, 2006 at 6:03 pm
    Hey mate thanks for the help, that worked a treat!
    dan
  • Steve Roberts
    February 21, 2006 at 6:12 pm
    Most excellent. 🙂
  • Sam Moulton
    February 23, 2006 at 3:20 am
    there is also a resize comp script in 6.5
