Activity › Forums › Adobe After Effects Expressions › Is there any way to use sourceRectAtTime() with Trim Paths?
  • Is there any way to use sourceRectAtTime() with Trim Paths?
    Posted by Andrei Popa on May 3, 2018 at 3:11 pm
    I am creating some handwriting effect and i am trying to add justification by adding an expression to the anchor. But when i animate the “End” of the trim paths to the shapes, anchor begins to float as the writing effect unfolds. I would like it to be in the place it is when the trim paths is at 100%. I thought of adding as time for the sourceRectAtTime() function the time of the last keyframe, but it is not always 100% in the last keyframe. Any ideas on how to do that? This is the expression i currently have
    myLeft = thisLayer.sourceRectAtTime(time,true).left;
    myTop= thisLayer.sourceRectAtTime(time,true).top;
    myHeight = thisLayer.sourceRectAtTime(time,true).height;
    myWidth = thisLayer.sourceRectAtTime(time,true).width;
    temp = effect('AE Handwriter')('Justification');
    if (temp == 1){
    [myLeft + myWidth/2,0]
    }else if(temp == 2){
    [myLeft,0];
    }else{
    [myLeft + myWidth,0]
    Works perfectly on 100% Trim paths, but very bad in animation.
    Andrei
    My Envato portfolio.
    Andrei Popa replied 8 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
