Activity Forums Adobe Premiere Pro Is there any way to rescale stills imported at default project size (720 x 576)?
  • Is there any way to rescale stills imported at default project size (720 x 576)?
    Posted by Peter Corbett on February 12, 2007 at 6:38 am
    I just imported a friend’s project which consisted of stills originally imported to default project frame size PAL 720 x 576. The actual stills are around 3000 x 2000 in size. I just want to do some zooms, but I can’t reset the scale on the clips in the timeline. Any clues?
    Peter
    Peter Corbett
    Powerhouse Productions
    http://www.php.com.au
    Perry Cheng replied 19 years, 7 months ago 4 Members · 6 Replies
  • Mike Velte
    February 12, 2007 at 12:27 pm
    Make sure “Default scale to frame size” is deselected in Preferences>General prior to importing the stills.
    Then;
    You probably cant see the bounding box around the still in the Program monitor…the stills are so huge. An easy method to resizing stills in the timeline is to select one and in the Effect Controls palette, change the scale to 25-35%, then select the remaining stills in the timeline and choose Edit>Paste Attributes. Make sure the stills are the same size to begin with. For 8 MP photos (3264X2448) 25% scale will leave enough in excess of 720 X 576 to do pan/scan AND still see and manipulate the bounding box in the Program Monitor.
  • Peter Corbett
    February 12, 2007 at 8:51 pm
    Hi Mike,
    Thanks for that. Yes I have the bounding box unchecked, but the original project which was done an another computer had it checked for default size import, so when I imported the other person’s project, the stills came in reduced in size even though I had deselected the frame size restriction on my computer.
    Peter
    Peter Corbett
  • Steven L. gotz
    February 12, 2007 at 10:04 pm
    Select all of the stills that you want to resize and right click, deselecting “Scale to Frame Size”. You then have to scale them yourself.
    Steven
    https://www.stevengotz.com
  • Peter Corbett
    February 12, 2007 at 10:11 pm
    Bingo. Thanks Steve. One never stops learning new things in this business.
    Peter
    Peter Corbett
  • Steven L. gotz
    February 13, 2007 at 1:31 am
    That’s why we all hang out here, isn’t it. 🙂
    Steven
  • Perry Cheng
    February 14, 2007 at 11:34 pm
    Steve, is this a 2.0 feature? Not in 1.5?
    Perry
