Activity › Forums › Adobe Premiere Pro › Is there any way to read time (in mins, secs and frames) between in and out points, like in Avid?
  • Is there any way to read time (in mins, secs and frames) between in and out points, like in Avid?
    Posted by Scott Clements on December 3, 2015 at 9:59 pm
    In Avid, you mark an in and an out point and can immediately see how much time (in minutes, seconds and frame) is between those points. I find this really handy, but don’t see anything like that in Premiere. It is very handy to not have to do math, when someone quickly says, how long is it between that point and that point? Does Premiere not have anything like this?
    Film Editor, London UK
    http://www.scottclementseditor.com
    Tero Ahlfors replied 10 years, 10 months ago 4 Members · 4 Replies
  • Jerry Wise
    December 3, 2015 at 10:49 pm
    sure. mark your in and out and then look at the “Program” pane and in the lower right corner you will see your time in min/sec/frames.
    Or you can also select a clip and hit “Mark Selection” and you will get the duration of that clip. very handy.
  • Michael Pekic
    December 3, 2015 at 10:55 pm
    You can find this in the record-monitor. The counter right below the screen gives you the desired information.
    Michael Pekić
    http://www.pekic.de
  • Scott Clements
    December 4, 2015 at 10:56 am
    Wow! Thanks, guys!!!
  • Tero Ahlfors
    December 4, 2015 at 11:24 am
    You can also see the duration of the selected clip in the info tab, if you’re using that.
