Activity Forums Avid Media Composer Is there any problems with digitizing a one hour BetacamSP tape in a Avid Media Composer
  • Is there any problems with digitizing a one hour BetacamSP tape in a Avid Media Composer
    Posted by Eddie Lopez on November 22, 2008 at 1:05 am
    Is there any problems with digitizing a one hour BetacamSP tape in a Avid Media Composer? Or do I need to digitize in 30 minutes chunks?
    —Eddie
    Grinner Hester replied 17 years, 10 months ago 5 Members · 5 Replies
  • Michael Hancock
    November 22, 2008 at 4:44 am
    You can capture an hour, but you need to go to your Capture settings and change the maximum time you can capture to 70 minutes. You may think, “70 minutes? Buy I have a 60 minute tape!” True, but hour tapes are often just a little over an hour, and 70 minutes should give you enough headroom to get the entire tape.
    Michael.
  • Terence Curren
    November 23, 2008 at 5:42 am
    Set the bugger for 180 minutes and don’t think about it any more. This is a hold over from the days when storage was EXPENSIVE!
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • Eddie Lopez
    November 24, 2008 at 6:16 pm
    Will digitzing the entire 1 hour tape cause any problems? A friend of mine, told me that his editor insist it be done in chunks rather as a whole.
    Thanks for reponses so far! 🙂
    —-Eddie
  • Dino
    November 25, 2008 at 2:01 pm
    Depending on the health/stability of the system and it’s storage, there may be a problem with long captures. If the system is in good shape an hour (or two) should not be a problem.
    Just set in and out points and capture. If there is a failure, the system will stop and let you save whatever was actually captured. Then just pick up the remainder. If you log and batch capture it will fail completely.
  • Grinner Hester
    November 27, 2008 at 7:21 pm
    60 is fine. I do it everyday.
