Activity › Forums › Compression Techniques › Is there any possibility for Wowza multiple streams can be merge to one stream ?
  • Is there any possibility for Wowza multiple streams can be merge to one stream ?
    Posted by Dskumar Gutti on November 25, 2012 at 6:17 am
    Hi all,
    i am new to the wowza media server, i am trying to merge the multiple streams into one file,is there any possibility to achieve this by wowza please send your great suggestions it is appreciable.
    Thanks in Advance
    Dskumar Gutti replied 13 years, 10 months ago 2 Members · 2 Replies
  • Lou Logan
    November 29, 2012 at 6:45 pm
    The is the FFmpeg COW forum. Are you using ffmpeg? If yes, what command have you tried?
  • Dskumar Gutti
    November 30, 2012 at 10:57 am
    1) cut the actual stream file with the following command
    e:\ffmpeg\bin\ffmpeg -ss 0:1:0 -i C:\VideoFiles\streamfile.flv -t 0:1:5 C:\VideoFiles\output.flv
    here, 0:1:0 (hh:mm:ss) & same as for 0:1:5
    repeat the same for all the streams
    2) extract the audio streams form (n-1) streams using the following
    e:\ffmpeg\bin\ffmpeg -i C:\VideoFiles\output.flv -vn -ar 44100 -ac 2 -ab 192 -f mp3 C:\VideoFiles\output.mp3
    repeat for all the other streams
    3) mix all outcomes into one audio file using the following
    e:\ffmpeg\bin\ffmpeg -i C:\VideoFiles\out1.mp3 C:\VideoFiles\out2.mp3 C:\VideoFiles\MERGE_FILE.mp3
    and combine the all output files in to one using the following command
    4) append the final audio + video file using the following
    e:\ffmpeg\bin\ffmpeg -i C:\VideoFiles\MERGE_FILE.mp4 -i C:\VideoFiles\MERGE_FILE.mp3 -ar 44100 C:\VideoFiles\finaloutput.mp4
