Activity › Forums › Apple Final Cut Pro Legacy › is there any good rule of thumb for estimating size of exported file or length of time it will take to export?
  • is there any good rule of thumb for estimating size of exported file or length of time it will take to export?
    Posted by Noam Osband on February 14, 2012 at 7:09 pm
    I’m usually left without any clue how long it will take something to export and how large it will be. Anyway to try and judiciously estimate that?
    Bouke Vahl replied 14 years, 7 months ago 2 Members · 2 Replies
  • Bouke Vahl
    February 15, 2012 at 10:01 am
    Well, i disagree on both points.
    Render time depends on system speed (as not all fx are done by the CPU, GPU also comes into play), and more it depends on the sort of fx used, and of course the amount.
    If there are no effects, and the output is same as source, it depends on drive speed rather than CPU/GPU speed.
    Now for size calculation. If you output to a fixed datarate codec, why would one need a calculator?
    example, DV runs at 25 Mb/sec.
    Thus a 10 seconds show will be 250 Mbits. That was fast 🙂
    The trouble occurs on rendering to some modern codecs. Sometimes they refuse to use the rate you want them to, so you end up with a file smaller than expected…
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Bouke Vahl
    February 15, 2012 at 5:29 pm
    Sure, you’re right.
    I was mixed up with another thread where someone asked about file sizes for AVCHD 100Mbits.
    Now that seems a dead givaway for datarate 🙂
    Bouke
