Activity Forums AJA Video Systems is there an OSX software codec for kona lh?
  • is there an OSX software codec for kona lh?
    Posted by Bob Flood on January 4, 2006 at 6:33 pm
    looking to convert a bunch of downloaded stock samples so i can play them in my dv sequence. is there a software codec i can put on my web machine to make kona native files?
    if not, whats a QT codec thats good AND fcp can treat natively?
    thanx in advance again
    bee eph
    Jeremy Garchow replied 20 years, 8 months ago 3 Members · 3 Replies
  • Robert Ober
    January 5, 2006 at 1:12 am
    [Bob Flood] “so i can play them in my dv sequence.”
    If by dv you mean DV as in DV25, why not convert them to DV? What am I missing? What is your “web machine capable of? Maybe install QT Pro on the web machine? What is the current format of the samples?
    Take care,
    Robert A. Ober
  • Bob Flood
    January 5, 2006 at 2:35 pm
    thanx
    yer not missing anything. kind of a confusing post i guess. i realized after the fact i could do a dv export out of QT pro, but i still wonder if there are 8 bit and 10 bit kona software codecs for os-x?
    bee eph
  • Jeremy Garchow
    January 6, 2006 at 11:18 pm
    Aja/Kona 2 generally use the Apple codecs. If you have the Kona 2 software installed, AJA has codecs for use with different situations if you so desire. look in your hard drive>library>quicktime folder, and copy whatever codecs you want from your FCP machine to your “web machine”.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
