Activity Forums VEGAS Pro Is there an option to change multiple clips’ Event Pan/Crop settings?
  • Is there an option to change multiple clips’ Event Pan/Crop settings?
    Posted by Ben Win on July 9, 2013 at 2:52 am
    I make these “pitch-shifting” videos that are often paired with fancy visuals and such. The most common of these visuals being Flip Horizontal. It’s where one flips every other clip so it looks like each note is changing the clip. PurpleSky091 utilizes this in this video: https://www.youtube.com/watch?v=jXASzd3YBX8
    I usually don’t do the visuals until I’m done with the audio, but that means I have to go through every single ***** *** **** ****** clip and open Event Pan/Crop, Right click the middle, click Flip Horizontal, close the window, and locate the next clip. Is there a way for me to flip all selected clips, so I can just go through and select all the clips that need to be flipped?
    Thanks again!
    Ben
    This community is very helpful 😀
    Aleksey Tarasov replied 13 years, 1 month ago 2 Members · 1 Reply
  • Aleksey Tarasov
    July 9, 2013 at 4:56 am
    If all your clips have the same frame size, use Edit > Paste Event Attributes command (the details are in the help). Otherwise, Vegasaur can flip your clips with ease.
    grading presets
