Activity › Forums › Adobe After Effects › Is there an “IGNORE ADJUSTMENT LAYER” effect/function?
Posted by Sean Worsell on October 1, 2010 at 3:44 amIf I have a gazillion layers and want to make a global change to them, obviously a single adjustment layer over the whole thing is the easiest method. But let’s say that the adjustment layer does exactly what I need for all the layers EXCEPT one or two. It is not always practical to move the one or two layers in question above the adjustment layer (so as to avoid the adjustment layer’s effects) or wrangle with precomp after precomp. Is there another way to simply select a layer and have it “ignore” any and all adjustment layers above it?
Tero Ahlfors replied 8 years, 11 months ago 7 Members · 8 Replies -
Todd Kopriva
October 1, 2010 at 7:34 amNo.
This question (which is somewhat common) demonstrates a lack of understanding of how adjustment layers work, so I’ll explain.
Some people say that adjustment layers “apply to all the layers under them”. If that were true, your request would make sense.
However, the truth is that an adjustment layer applies to one thing: the composite of the layers beneath it. WHat is rpesented to the adjustment layer to operate on is essentially a single layer—the result of all of the compositing operations done up to that point in the layer stack (wrking up from the bottom).
So, no.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Sean Worsell
October 1, 2010 at 8:50 amThanks. I see what you’re saying…I’ll continue to use my workarounds. Cheers.
Steve Roberts
October 1, 2010 at 4:23 pm[Todd Kopriva] “However, the truth is that an adjustment layer applies to one thing: the composite of the layers beneath it.”
Excellent distinction, sir.
Cassius Marques
October 1, 2010 at 9:41 pmI, sometimes precomp the layer’s i want to exclude, and use that as alpha’s inverted matte to the adjustment.
It is not a perfect solution, since you can have transparency and stuff. but sometimes it does the job.
cheers.
Roland R. kahlenberg
October 4, 2010 at 4:19 pm[Todd Kopriva] “… (wrking up from the bottom)”
I think most folks are not knowledgeable that for 2D layers AE renders from the lowest layer in the timeline stack and works its way upwards.
Having said that, this still shouldn’t preclude having a “NoAdjustment Layer” as part of the layer stack. The “NoAdjustment Layer” could still work as the render engine works its way upwards within the stack. What a “NoAdjustment Layer” does is to tell any forthcoming Adjustment Layer to not include layers below it in the composite that the Adjustment Layer is applied to.
It’s a lot like applying a dummy effect to a 3D layer to deliberately break its 3D interaction with other 3D layers.
Sense Make?
AE Training in South East Asia. AE templates for sale and rental. Click here for more
Todd Kopriva
October 4, 2010 at 4:26 pm> Sense Make?
No.
Adjustment layers aren’t “told” anything about layers beneath them. The output of the rendering operation right before the adjustment layer is a single composite. The adjustment layer acts on that composite. There is no (practical) way to disentangle what contribution a given layer made to that composite.
That said, if you want to request a change to how adjustment layers work, please fill out a detailed feature request explaining how you want things to work:
https://www.adobe.com/go/wishTalking about it here on this forum thread is not at all helpful, since the people who would implement such changes almost certainly won’t see this forum thread—but they will certainly see a feature request made through the feature-request form.
Will Coles
September 25, 2017 at 3:40 amActually Todd, you are the one who has the lack of understanding.
Click the adjustment layer properties and there is a square with and arrow down. Click on that and presto.
Tero Ahlfors
September 25, 2017 at 11:01 amJust a heads up: You just replied to a SEVEN YEAR OLD THREAD.
