Activity Forums Adobe After Effects Expressions Is there an expression references the effect?
  • Dan Ebberts
    July 5, 2008 at 5:08 pm
    You can use propertyGroup() to go up the chain. For example, propertyGroup(1).name.length will give the length of the name of property group one level up, which might be the effect itself.
    If not, try propertyGroup(2).name.length and so on until you get to the effect level.
    Dan
  • Jamie Bradshaw
    July 5, 2008 at 8:12 pm
    Thanks loads Dan. I’m using the expression:
    propertyGroup().name.length;
    and it’s returning the length of the effect name. Just what I was after.
    One again you save the day! 😉
    Jamie Bradshaw
    Motion Graphic Artist
    https://www.vimeo.com/jimjam
