Activity › Forums › Adobe After Effects Expressions › Is there an expression code for random positions of repeating starting and ending fireworks effect?
  • Is there an expression code for random positions of repeating starting and ending fireworks effect?
    Posted by Kyle Balitz on April 29, 2020 at 5:54 am
    I am trying to create an automated fire works show. The animation is 5 seconds flat. Is there a good random expression programming code for randomizing starting and ending positions of fire works shooting off from the bottom to the top of the screen.
    I have set three key frames. And would like the trail layer to start from a random y position and shoot off into a random x & y position in 5 seconds which I will loop. Do I have to separate dimensions? And does this require a slider? Is it possible? Perhaps an if statement?
    Note: I know I can do posterize time for the explosion, but the random shooting off part makes things a bit more difficult. The trail is supposed to connect to the firework position in some way.
    holdTime = 5; //time to hold each position (seconds)
    seed = Math.floor(time/holdTime);
    seedRandom(seed,true);
    random(0,1920)
    NULL LAYER
    temp = thisComp.layer("Null 2").effect("Slider Control")("Slider");
    [value[0], temp]
    FireWorks Layer connected to slider
    Kyle Balitz replied 6 years, 5 months ago 2 Members · 2 Replies
  • Robert Müller
    April 29, 2020 at 11:01 am
    Hi, you seem to be using a plugin for the firework. Which one?
  • Kyle Balitz
    April 29, 2020 at 8:07 pm
    Hi Robert, Sorry for the lack of information, I am using Trap Code Particular.
