Activity › Forums › Apple Final Cut Pro Legacy › Is there an alternative to Proxy Mill?
  • Is there an alternative to Proxy Mill?
    Posted by Ned Miller on April 19, 2013 at 11:52 pm
    I often need to quickly make a copy of the footage I shoot, preferably with visible time code, in a file small enough to send via Yousendit which is under 2GB. This is for clients to choose takes, sound bites or get approval.
    Sometimes it takes too long to go through the whole FCP process and then export. I know about Proxy Mill. I was wondering if anyone knows of a similar product?
    Ned Miller
    Chicago Videographer
    http://www.nedmiller.com
    www,bizvideo.com
    Neil Patience replied 13 years, 5 months ago 3 Members · 2 Replies
  • Shane Ross
    April 19, 2013 at 11:57 pm
    Compressor. If you make a preset that includes timecode burn. But it does require a bit of compressing knowledge to get all the settings right. That’s why I prefer the simplicity of Proxymill.
    Shane
    Little Frog Post
  • Neil Patience
    April 20, 2013 at 12:18 am
    Hi Ned
    Obviously not specialist software like ProxyMill but this could speed up your workflow depending on the method you currently use.
    Shane Ross did a good tutorial on this using FCP7 and Compressor which while not as quick or easy as ProxyMill speeds up the process a good amount.
    Worth a look and obviously free.
    https://library.creativecow.net/ross_shane/visible-timecode/1
    EDIT – Oh well the man himself got there first !
    best wishes
    Neil
    http://www.patience.tv
    8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
    i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7
