Activity Forums Apple Final Cut Pro Legacy Is there a way to…
  • Is there a way to…
    Posted by Jason Mccaffrey on July 28, 2005 at 8:20 pm
    …make the video image bigger while I am trying to key a garbage matte? I’m blurring a license plate and going blind trying to do it with accuracy. It would be fantastic if I could blow up the license plate so I could really see the corners of it. Thanks for any help in advance.
    Jason
    400 MHz Power Mac G4 2.9
    832 MB SDRAM
    (256 256 256 64=832-everyone asks)
    FCP 4.5
    QuickTime 6.5.2
    Kevin Monahan replied 21 years, 2 months ago 4 Members · 3 Replies
  • Bouncing Account needs new email address
    July 28, 2005 at 8:43 pm
    Make the Viewer (or Canvas) Window as big as you like (for the time it takes you to work on something small).
    Just drag the lower right-most corner of the window out and down.
    After you’re done, drag it back to where it normally fits, then make sure you still have “Fit to Window” selected.
  • Harley Michailuck
    July 28, 2005 at 11:49 pm
    [Jason McCaffrey] “if I could blow up the license plate so I could really see the corners of it.”
    You can open Universal Access in System Prefs and turn on Zoom, then in FCP select the Viewer and use “Apple =” to zoom in on the portion you want to work on.
    Best,
    Harley
    Harley Michailuck
    Brass Orchid Post fx
    Saskatoon, SK Canada
    https://www.brassorchid.com
  • Kevin Monahan
    July 29, 2005 at 12:36 am
    Simply zoom in on the Canvas: Command +++++++ gets you there the fastest.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
