Activity › Forums › Adobe Premiere Pro › is there a way to use markers to split a video?
Posted by Ali Brakat on February 8, 2017 at 4:02 ami have a video that i want to cut into many many parts it would take forever but if there is a way to mark the points and then split at these markers and export separated videos that would be great is there any tool or a software that can do that ???
Andy Patterson replied 9 years, 7 months ago 5 Members · 6 Replies -
Ole Kristiansen
February 8, 2017 at 11:56 amIf you are on a Windows PC it is easy with Vegas Pro – I made a simple guide to show how to do !
Split is S – and Insert Region is R on the keyboard – and then just Batch Render !https://www.youtube.com/watch?v=vo095lPxgLI&feature=youtu.be
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Chris Wright
February 9, 2017 at 2:22 amturn all the markers in a single clip into subclips.
Here’s how to do it.
Load a clip from the Browser into the Viewer.
Put your playhead where you want a subclip to start and place a marker by typing “M“. You can put as many markers in a clip as you want.
Notice that the clip in the Browser now has a triangle next to the name. Twirl down the triangle to see a list of all your markers.
Rename the markers as you wish.
Create a new Bin in the Browser (press Command+B).
Here’s the magic part… select and drag all the markers from the clip in the Browser into the bin you just created. As soon as the markers are dropped into the Bin they are instantly converted to subclips.or in AE
split selected layers at their layer markers
https://aescripts.com/pt_layermarkers/ -
Yair Bartal
February 9, 2017 at 6:12 amI couldn’t see a triangle next to the name so I couldn’t follow your tip.
Can you post a screen dump to show it?Thanks.
Chris Wright
February 9, 2017 at 7:35 amthat’s the FCP way, pasted text got cut off last post.
manually, you can kind of do it in premiere, with in and out points per clip, clip make subclip – enable restrict trims to subclip boundries. -
Andy Patterson
February 9, 2017 at 7:53 amThe video link below might be of some interest. You can also make a feature request.
