Activity Forums Apple Final Cut Pro Legacy Is there a way to Un-nest
  • Is there a way to Un-nest
    Posted by Eriq Wities on October 8, 2007 at 9:56 pm
    I’m working in FCP 5.0
    Is there a way to un-nest nested clips, short of copying and pasting them back into the timeline? Seems like it should exist, but I haven’t been able to find that feature yet. Thanks.
    Martha Stiegman replied 15 years, 5 months ago 6 Members · 5 Replies
  • Walter Biscardi
    October 8, 2007 at 10:48 pm
    Not that I know of. I simply Open the Nest, Select All, and Drag all the items back into the working timeline.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Kevin Monahan
    October 9, 2007 at 3:50 pm
    Command + Drag the Sequence icon from the Browser to the Timeline.
  • Nick Meyers
    October 9, 2007 at 5:44 pm
    there is a way to de-nest.
    basically you open the nested sequence from the timeline into the viewer window.
    make a subclip.
    now the nested sequence has been trimmed to the section used.
    NOW you can apple-drag it to the timeline, and get the clips you want/need.
    this comes up every couple of weeks,
    so HERE’S A (probably over-detialed) HOW-TO
    NESTS: How to De-Nest
    I’ve been editing from Sequences I’ve loaded into the viewer,
    and now my timeline is all NESTS, not CLIPS!
    How do i get back to having clips in the timeline?
    OVERVIEW
  • Barry Sales
    June 12, 2010 at 3:54 pm
    That sounds messy. I just ran into the same problem.
    Fortunately, I’m a pack rat so I went to a previously saved cut and copy & pasted the section I needed.
    The most efficient way I would think would be to double click the nested Picture timeline, then copy it into another sequence. Do the same for the Audio but ensure it’s at the correct starting place.
    That should put you in the ball park to edit again.
  • Martha Stiegman
    April 1, 2011 at 5:03 pm
    hi
    glad to discover this – i’m in un-nesting hell: i was advised at the beginning of this project to downconvert from HDV to DV then recapture once i got towards a fine cut (i was nervous about my computers ability to process HDV).
    I’m at the recapturing step now, and one of the problems i’m having is that all my “subclips” are nested – therefore i can’t recapture them unless i manually unnest each and every one – i’m working from 30 tapes so that’s not a workable scenario.
    question 1: how did all my subclips become nested to begin with? i never intentionally nested any of them
    question 2: is there another way out of this besides the manual reconstruction of this entire project?
    thanks
    martha
