Activity › Forums › Adobe After Effects › Is there a way to stop warp stabilizer but keep the framing?
  • Is there a way to stop warp stabilizer but keep the framing?
    Posted by Jensen Yancey on February 15, 2017 at 4:03 pm
    I would have thought this problem would come up more often, but I’m having a hell of a time googling a fix. I have a clip that needs stabilization, and warp stabilizer is working perfectly on the problem part of the clip, the issue is there’s another section where it just goes crazy. Is there a way to stop after effects (or premiere, if that’s easier) from trying to stabilize certain parts of the clip while maintaining the cropping and rotation that it applies to the parts I want stabilized?
    Roei Tzoref replied 8 years, 2 months ago 5 Members · 5 Replies
  • Jensen Yancey
    February 16, 2017 at 10:36 pm
    Well, I guess a better way to ask it is, is there a way to either:
    A. easily match up the framing and rotation of a non-warp stabilized clip so there’s no visible transition.
    B. Tell warp stabilizer to ignore the sections that are causing it to have a seizure.
  • Jim Arco
    February 20, 2017 at 1:05 pm
    I think I would just split the clip “where it just goes crazy” and stabilize the un-crazy clip. You may need to manually move one of the clips so that the beginning/end match up correctly.
    Jim
  • Soham Jani
    February 21, 2017 at 12:26 am
    Yeah, either make another comp and drag the clip in it and shorten it to where you want to do the effect, or cut it up in PP and toss it in AE.
  • Amy Young
    July 6, 2018 at 6:48 pm
    I also wish there were such a feature, something like “Keep the warp/scale settings HERE for n seconds of the clip….”
    One thing I do to get frames to line up (as best I can) is to work a while in “Difference” mode for the transparency setting for the “top” layer. I got the idea from stop-motion software. It helps you see what has changed between two frames.
  • Roei Tzoref
    July 7, 2018 at 1:28 pm
    [jensen yancey] “I would have thought this problem would come up more often, but I’m having a hell of a time googling a fix. I have a clip that needs stabilization, and warp stabilizer is working perfectly on the problem part of the clip, the issue is there’s another section where it just goes crazy. Is there a way to stop after effects (or premiere, if that’s easier) from trying to stabilize certain parts of the clip while maintaining the cropping and rotation that it applies to the parts I want stabilized?”
    Unfortunately, No. it’s an automatic tool for better and for worse. you have other methods of stabilizing which are controlled by keyframes like Stabilze Motion (which will use conventional 2d Tracking) or you could use Mocha. there is a tutorial here that offers a workaround for converting WS to keyframes. you can try it:
    https://www.toolfarm.com/blog/entry/tutorial_how_to_get_better_control_of_warp_stabilization
    this is a nice FR idea, please add your vote here:
    https://adobe-video.uservoice.com/forums/911311-after-effects/suggestions/34770673-warp-stabilizer-add-keyframes-to-control-between
    [Dave LaRonde] “AE stabilizes the ENTIRE clip, regardless of in & out points.”
    this is incorrect. warp stabilizer will only stabilize between the in and out points of your clip. all you have to do is trim it. this won’t help much if it’s the same shot because there will be a jump that is impossible to fix.
    Roei Tzoref
    2D/VFX Generalist & Instructor
    ♫ AeBlues Tutorials ♫
    http://www.tzoref.com
