Activity › Forums › Adobe After Effects › Is there a way to separate audio from a video file?
  • Is there a way to separate audio from a video file?
    Posted by Andy Kelly on July 3, 2015 at 8:41 pm
    I feel like this super simple, but I’ve been looking online for a half hour and can’t find a solution.
    I’m using AE CS6. I’m trying to cut a video clip, while keeping the audio on that clip going. I saw a video of someone extracting an audio clip using the preview window, but I can’t find the button in AE6.
    My current work around is to set the opacity of the clip to zero using Hold Keyframe, but there’s gotta be a better way.
    Any guidance would be greatly appreciated. This is driving me nuts.
    Thanks!!
    John Cuevas replied 11 years, 2 months ago 2 Members · 2 Replies
  • John Cuevas
    July 4, 2015 at 2:27 pm
    Just duplicate the clip, turn off the opacity(use the eyeball) and you now one clip for your audio. On the clip you are going to cut, turn off the audio(speaker) and that’s your video clip.
    Otherwise, you could just drag the file into audition and save out a .wav file that’s separate from your video clip.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Andy Kelly
    July 5, 2015 at 5:04 pm
    That makes sense. Thanks.
