Activity Forums Apple Final Cut Pro Legacy Is there a way to save logging info between cards and sessions?
  • Is there a way to save logging info between cards and sessions?
    Posted by Noam Osband on February 16, 2011 at 4:34 pm
    Two questions:
    1 – I’m logging AVCHD footage. Each time I go to a new clip, all the logging info needs to be re-entered. Sometimes though, it’s the same thing, and I want to keep the scene and shot the same over multiple clips. Is there a way to do this?
    2 – Is there a way to save logging info so I have the presets saved everytime I turn on FCP? It seems like it’ll save your different choices, e.g. the different scenes you have entered, during the same session, but that after you close FCP and open it later, all that is lost. Can I change that?
    Jeremy Garchow replied 15 years, 6 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    February 16, 2011 at 8:25 pm
    [Noam Osband] “Sometimes though, it’s the same thing, and I want to keep the scene and shot the same over multiple clips. Is there a way to do this?”
    FCP7? Check out the “Name Preset” capabilities in L&T. It works ok.
    [Noam Osband] “Can I change that?”
    Again, check out the presets. You can save different ones.
  • Noam Osband
    February 16, 2011 at 10:06 pm
    This sounds like a dumb question, but where is the “name preset” capability? I’ve looked online for this and in FCP but can’t find it.
    And, yeah, it’s FCP 7
  • Jeremy Garchow
    February 16, 2011 at 10:10 pm
    [Noam Osband] “This sounds like a dumb question, but where is the “name preset” capability?”
    In the log and transfer window on the bottom right side with all the logging information, there’s a drop down menu called the Name Preset. You should mess around with it.
    Jeremy
