Activity Forums Apple Final Cut Pro Legacy Is there a way to reduce render time?
  • Is there a way to reduce render time?
    Posted by Mabel Lau on August 12, 2013 at 10:50 am
    Hi all,
    I’ve got a hour sequence that I need to render, but it says it’ll take 3 hours to render. The sequence setting is ProRes (LT) 1920x 1080 and the footages are ProRes (LT) as well. My computer config is as follows:
    Model Name: iMac
    Model Identifier: iMac10,1
    Processor Name: Intel Core 2 Duo
    Processor Speed: 3.06 GHz
    Number of Processors: 1
    Total Number of Cores: 2
    L2 Cache: 3 MB
    Memory: 16 GB
    Bus Speed: 1.07 GHz
    Boot ROM Version: IM101.00CC.B00
    SMC Version (system): 1.52f9
    Is there any way I can reduce the render time?
    Thanks in advance.
    Mabel
    Shane Ross replied 13 years ago 4 Members · 5 Replies
  • Stephen Smith
    August 12, 2013 at 2:56 pm
    When you bring a clip in you shouldn’t need to render at all. If you applied a filter such as one to give you time code or something, then you will need to render. If you only have a clip in the time line then delete it and bring it back into the timeline. FCP will ask you if you want to change your settings to the same as the clip. Click yes. If you are working with RAW files from a camera like the Cannon 7D, you shouldn’t bring those into FCP. Although they are .MOV files they are H.264 files. You need to log and transfer them to say Pro Res and then bring them in. Hope this helps.
    Stephen Smith – Follow me on Behance
    Utah Video Productions
    Check out my Vimeo page
  • Shane Ross
    August 12, 2013 at 5:31 pm
    Different filters have different render times, depending on the complexity. For example, NEAT VIDEO is a plugin that cleans up your image. But does so at a cost. adding it to 5min of footage means a 20-30 min render. I had it sporatically over a 45 min show, and the render time was 17 hours.
    Only way to increase render speeds is faster processors…something you cannot swap out in Macs.
    Shane
    Little Frog Post
  • Mabel Lau
    August 13, 2013 at 1:58 am
    Thanks guys, I guess the only solution is to get a new imac with faster processor.
  • Jim Murphy
    August 20, 2013 at 12:03 pm
    Would upgrading the GPU help at all?
  • Shane Ross
    August 20, 2013 at 4:43 pm
    GPU would only help with GPU enabled plugins. Nothing else.
    Shane
    Little Frog Post
