Activity Forums Apple Final Cut Pro Is there a way to record live camera feed into FCP edit window like audio?
  • Is there a way to record live camera feed into FCP edit window like audio?
    Posted by Gabriel Raphael on March 13, 2022 at 7:11 pm
    Hi
    Im surprised that there are as little to no applications on Mac that record video like audio, even if its hardware dependant., The Quicktime App can be duplicated to capture multiple cams via USB, USB-C or FW etc and OBS live streams multiple cams yet nothing out there allows one to simply connect a camera – dslr etc (not fake time) and record directly into their timeline just as if you do with DAWs (audio).
    Does anyone know of a solution for this?
    Michael Alberts replied 4 years, 5 months ago 3 Members · 2 Replies
  • Andreas Kiel
    March 14, 2022 at 4:32 pm
  • Michael Alberts
    March 16, 2022 at 12:39 am
    I second the Softron MovieRecorder. I’ve been using it for at least five years now. It’s an amazing piece of software. You can upgrade to their hardware based systems depending on how many streams you need to record. I use it mainly for live editing in FCP. Once the stream starts you can start editing in FCP after about 3-4 seconds.
