Activity › Forums › Maxon Cinema 4D › Is there a way to manipulate baked dynamics keyframe?
  • Is there a way to manipulate baked dynamics keyframe?
    Posted by Sujen Bajracharya on September 16, 2019 at 9:40 pm
    Hey Guys,
    I am animating a bunch of papers flying using dynamics. I baked the dynamics to PLA animation keyframes, Is there a way to manipulate the keyframe in this case i want to rotate the paper when it comes infront of the camera , i dont care if i have to do it frame by frame its not too much frames. I tried doing it but the animation jumps back to the same position even if i changed it. I would really appreciate any suggestion.Thanks
    Brian Jones replied 7 years ago 2 Members · 1 Reply
  • Brian Jones
    September 17, 2019 at 3:11 pm
    there should be, keyframes have to be resaved if you change the values though, so after you make a change in the rotation you’d have to hit the keyframe circle to make it red again (or use the keyframing buttons)
