Activity Forums Adobe After Effects Expressions Is there a way to make the wiggle expression create hold keyframes?
  • Is there a way to make the wiggle expression create hold keyframes?
    Posted by Daniel Haskett on November 7, 2007 at 3:29 pm
    Hi there,
    Say you apply a wiggle (2,10) its gonna move 2 times a second and 10 magnitude…..but inbetween those 2 keyframes it tweens or whatever its called, moves around. is it possible so that the motion is more jerky, so it actually only moves twice a second as though it were 2 hold keyframes….does that make sense?
    cheers
    dan
    Tamara Tarek replied 6 years, 7 months ago 7 Members · 7 Replies
  • 7 Replies
  • Darby Edelen
    November 7, 2007 at 6:04 pm
    This should work for you:
    f = 2;
    a = 10;
    posterizeTime(f);
    wiggle(f, a);
    posterizeTime(x) causes the expression to only return an updated value x times per second. It must be called before the return value, which is the value returned by wiggle() in this case.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Santa Cruz, CA
  • Daniel Haskett
    November 7, 2007 at 6:16 pm
    mate you’re a legend, that works a treat and is nice and simple!
    cheers
    dan
  • Manojit Ghose
    November 10, 2016 at 10:01 am
    thanks! 🙂
    MG
  • Sam Bass
    February 22, 2017 at 11:27 pm
    How would you do this with uniform scale?
  • Dan Ebberts
    February 22, 2017 at 11:59 pm
    Like this:
    f = 2;
    a = 10;
    posterizeTime(f);
    w = wiggle(f, a);
    [w[0],w[0]]
    Dan
  • Stacy Bias
    September 29, 2017 at 5:21 pm
    Hey! This just really helped me, too — thanks!
  • Tamara Tarek
    February 13, 2020 at 12:07 pm
    Thanks! Very helpful
