Activity Forums Apple Final Cut Pro Legacy Is there a way to limit the Easy Setup choices?
  • Is there a way to limit the Easy Setup choices?
    Posted by Mark Arenz on April 28, 2005 at 2:05 pm
    I’ve Googled and found nothing on this issue, but it seems like it should be so simple. Even without Show All clicked, I get about 2 dozen options and it causes me fits when other folks that use the system grab something in the PAL preset (result: junk).
    I’ve gone through and tried to delete (or at least move) files that appear to be Easy Setup files but it hasn’t worked so far.
    Adam Schmidt replied 21 years, 5 months ago 2 Members · 1 Reply
  • Adam Schmidt
    April 28, 2005 at 4:18 pm
    In the easy setup dioluge box, there is a “show all” button that will display all presets in the computer. Turning this off will limit you to just the setups that fcp shiped with. Also in Hard Drive/Library/application suport/ final cut pro support/custom setups you will find all the custom setups. If you trash these settings, the will no longer be avalibal in the easy setups dioluge.
    Adam
