Activity Forums Adobe After Effects Is there a way to keyframe parenting/unparenting???
  • Is there a way to keyframe parenting/unparenting???
    Posted by Doug Nash on June 3, 2011 at 5:55 pm
    As the Subject asks, is there a trick or an expression which can be used to essentially activate or deactivate the parent function at a given time?
    Jordan Santiago replied 10 years ago 5 Members · 7 Replies
  • 7 Replies
  • Walter Soyka
    June 3, 2011 at 6:00 pm
    Parenting is not keyframable — but you could split the layer [link] at the point where you want parenting to end (or begin again), then un-parent (or re-parent) the new layer as necessary.
    You could also write a series of keyframeable expressions that emulate parenting, but I think this would get complicated quickly.
    Walter Soyka
  • Doug Nash
    June 3, 2011 at 6:17 pm
    Thanks for the fast reply. I’m already splitting the layers, but with the complexity of the project I’m working on, that’s already getting hairy. That would be a very nice feature for Adobe to consider adding.
    I’m so spoiled, working with Cinema 4D all the time, as that program really sets the standard for flexibility.
  • Walter Soyka
    June 3, 2011 at 6:37 pm
    [doug nash] “I’m already splitting the layers, but with the complexity of the project I’m working on, that’s already getting hairy.”
    Yeah, it gets very hairy very fast. If you have a lot of effects work on those split layers, ft-Effect Instance [link] might help you keep them all in sync.
    [doug nash] “I’m so spoiled, working with Cinema 4D all the time, as that program really sets the standard for flexibility.”
    Off-topic now, but how would you accomplish dynamic parenting in C4D?
    Walter Soyka
  • Michael Szalapski
    June 21, 2011 at 8:14 pm
    I’m curious about the C4D dynamic parenting aspect as well.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Daniele De luca
    March 26, 2015 at 10:40 pm
    You can unparent a layer using this recursive function, e.g. fix (value, thisLayer)
    function fix ( pos , layer ) {
    if (layer.hasParent) {
    var p=layer.parent;
    pos = fix ( pos , p );
    var rp = degreesToRadians(p.rotation);
    var delta = pos – p.position;
    var s = p.scale / 100;
    delta = [ delta[0] / s[0] , delta[1] / s[1] ];
    rad = Math.sqrt ( delta[0]*delta[0] + delta[1]*delta[1] );
    if (delta[1] != 0) ang = Math.atan (delta[0]/delta[1]) else ang = Math.PI/2;
    dx = Math.sin (ang+rp) * rad;
    dy = Math.cos (ang+rp) * rad;
    if (delta[1]<0) {dx=-dx; dy=-dy};
    return [dx,dy] + p.anchorPoint;
    else return pos;
  • Jordan Santiago
    September 17, 2016 at 3:24 am
    Hi Daniele,
    Is there a downloadable demo of this function working available somewhere?
    -Jordan
  • Jordan Santiago
    September 17, 2016 at 4:56 am
    Hey there, just wanted to post another resource in case anyone else is having the same problem.
    I was looking for a way to dynamically switch between having one layer be parented to something and then turning it off.
    With this tutorial, you can do just that.
    https://vimeo.com/48790227
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
