Activity › Forums › Apple Final Cut Pro › Is there a way to have silent tracks removed from the timeline?
  • Is there a way to have silent tracks removed from the timeline?
    Posted by Noam Osband on September 3, 2015 at 5:05 pm
    I know FCP X gives you the option of removing silent tracks upon import. Is there any way to do that for clips which are already in the timeline?
    Bill Davis replied 11 years ago 3 Members · 5 Replies
  • Jeff Kirkland
    September 3, 2015 at 5:26 pm
    you can’t remove the channel but you can switch it off in the info panel so it doesn’t show when you expand the audio components, etc.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • Bill Davis
    September 3, 2015 at 5:49 pm
    Removing unneeded tracks in the storyline is largely track based thinking. Usually it’s bettter on global changes like this to go to the imported clip in the library Event – Open in Timeline – and delete whatever tracks you don’t want there (Amend at the database level, not downstream in the Storyline.) It’s still not not automatic (that’s only possible on import) but if you do it upstream like this, any subsequent use of each clip will be as you set it upstream.
    Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
  • Noam Osband
    September 4, 2015 at 2:14 am
    Bill, great tip. Thanks for it.
  • Noam Osband
    September 6, 2015 at 2:16 am
    Bill, will it retroactively affect clips in the timeline or only affect subsequent uses?
  • Bill Davis
    September 7, 2015 at 11:43 pm
    Subsequent only.
    Think of it like imports.
    When you “import” a clip to the timeline, it flows in with the metadata that exists for it “at the time” of import.
    If you go back and change the source clip, it just changes the NEXT time you import it into a new storyline.
