Activity Forums Adobe After Effects Is there a way to have a panel for basic transform information?
  • Is there a way to have a panel for basic transform information?
    Posted by Luke Mosse on January 7, 2020 at 3:16 pm
    Hi
    I’m interested in having a panel which will always show the basic transform information for any selected individual layer – similar to the ‘effects’ panel which shows you the effects parameters on a single layer.
    Is there a way to do this?
    It would save an awful lot of keyboard shortcuts and mouse clicks, opening up the relevant controls for each layer when I just want to adjust basic things like position and scale and have to wait for each shortcut to take effect.
    If anybody has any ideas please let me know!
    Tomas Bumbulevičius replied 6 years, 7 months ago 4 Members · 4 Replies
  • Drew Hutchison
    January 7, 2020 at 6:53 pm
    Hey Luke,
    If you’re setting up a large project and really just want to see the information immediately if you click on a layer you could always set up expression control effects on the said layer and parent the transform options to expression controls
    (ie. Seperate position coordinates and parent the x and y to a point controller.)
    That way you could use your effect palette as a pseudo transform palette.
    Hope this helps.
    -Drew H
  • Cassius Marques
    January 8, 2020 at 1:02 pm
    how about you apply the transform effect and use just that?
    Cassius Marques
    http://www.zapfilmes.com
  • Drew Hutchison
    January 8, 2020 at 8:08 pm
    Simple solution! Learned something new today. Always just used the hotkeys for transforming. Cheers!
  • Tomas Bumbulevičius
    January 12, 2020 at 6:15 pm
    Drew, just keep in mind ‘Transform Effect’ does not behave in the same way when parented/collapse transformed. So while it works great in some cases, in some it will fail (especially with positioning/anchor). Other than that, for simple transformations its definitely a good choice.
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
    Boxer – Dynamic Text Boxes Template with a Live Preview
