Activity › Forums › Adobe After Effects › is there a way to export a single frame in after effects?
  • Andrei Firtich
    November 6, 2005 at 1:50 am
    There is a number of things you can do…Simplest would be to use timeremap and freeze the frame…Another way would be to find whatever frame you need go to Save frame As, save it as a photoshop file then reimport it. If a frame is already preprocessed, then just import it as a stillstore, AE supports almost all formats.
    Hope this helps 🙂
  • Chris Smith
    November 6, 2005 at 4:08 am
    use ‘Save Frame as’ it’s right there in your menus.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Accountclosed
    November 8, 2005 at 2:19 am
    wow. didnt realize how simple it was. thanks!
