Activity › Forums › Adobe After Effects › Is there a way to display imbedded timecode?
Posted by Jim Arco on November 17, 2012 at 12:31 pmI sometimes need to know the date and time that a recording was made. Is there a way to view the timecode of the clip in After Effects? (or Premiere Pro?)
Jim
Jim Arco replied 13 years, 10 months ago 4 Members · 7 Replies -
John Cuevas
November 17, 2012 at 1:24 pmIf you expand your project panel though, and click by name, you can access the columns and add date(the date the clip was created). Some codecs and file types(quicktime) keep the source time code now too and AE(presumably Premiere too) will have that data available and you can turn that on and off in the project panel.(Media Start, Media End). Unless you set your timecode to time of day and free run, I don’t think you will get the time a clip was created.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Todd Kopriva
November 17, 2012 at 8:52 pmUse the Timecode effect.
After Effects team blog
Vishesh Arora
November 18, 2012 at 12:49 pmJim
Right click on the video file and go to Properties(Windows)and then go to Details Panel.
Scroll down and then you will get to know the “ Date Created ” with the exact Time.
Just add this information as a Text layer or if you want to animate it then you can use Numbers Effect.
Vishesh Arora
3D and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.comDemo Reel(3D):
https://www.youtube.com/watch?v=lHPgIJU_BR8 -
Jim Arco
November 18, 2012 at 1:19 pmThank you, I don’t know why I didn’t find that with a search. Apparently, I still can’t show the actual date that the source material was shot?
Additional strangeness:
When I add a file to AE CS5.5, the date that the file was created (in Windows) is shown, but when I add it to ‘create composition,’ the ‘date modified’ of the file is changed in Windows and AE. So everything winds up with today’s date.What is AE doing to change my files? And how can I prevent it?
Jim
Jim Arco
November 19, 2012 at 1:15 pmThanks Vishesh, but that only works for file-based video recording.
I am currently working with a bunch of video captured from DV tape and the “Date created” is the date the video was captured. (Also, AE seems to be changing that date to today’s date when I apply the timecode effect.)
Jim
Todd Kopriva
November 19, 2012 at 6:42 pm> When I add a file to AE CS5.5, the date that the file was created (in Windows) is shown, but when I add it to ‘create composition,’ the ‘date modified’ of the file is changed in Windows and AE. So everything winds up with today’s date.
XMP ID values are written to source files when they are imported into After Effects if the Write XMP IDs To Files On Import preference is selected in the Media & Cache preferences category.
Jim Arco
November 19, 2012 at 10:50 pmDave,
Thanks for the info. Actually what I need most is (unfortunately) the date that is imbedded in the video itself. Ideally, in a way that would be able to be used in an expression.
There are any number of utilities that let me look at the date and time that are contained in the video, but none integrate into PPro/AE.
Is this worth doing a feature request, or is this one of those things purposely omitted because someone else has the copyrights/patents already locked down?
Jim
