Activity › Forums › Adobe Premiere Pro › Is there a way to copy and paste a customized transition in PPro1.5?
  • Craig Howard
    February 27, 2006 at 12:10 am
    Save it as a preset and use the preset
  • Peter Corbett
    February 27, 2006 at 2:13 am
    I don’t think you can save transitions as a preset, only effects.
    Peter Corbett
    Powerhouse Productions
    Australia
    http://www.php.com.au
  • Perry Cheng
    February 27, 2006 at 2:42 am
    That’s what I was afraid of… that is so rediculous! It was so easy in 6.5, but not in Pro!????
    Perry
  • Craig Howard
    February 27, 2006 at 7:48 am
    Sorry gents. You are correct. YOu can not save a standard PremPro Transition as a preset.
    I confused my Saved Matrox Transition Presets and a couple of Effects Presets I had built and saved as transitions. eg ‘Camera Flash’ and ‘dip to white’
  • Peter Corbett
    February 27, 2006 at 7:55 am
    That’s not to say there shouldn’t be a preset for transitions. Next version.
    Peter Corbett
    Australia
  • Hector Melendez
    February 27, 2006 at 3:01 pm
    Very uncomfortable to get the last of NLE and not having such as a standard things… that my old Screenplay (from Applied-Magic) editor have for more than 8 years back.
    This is one of the most objetable concerns I have with PP, same as the making of changes to clips,ie; same lenght to bunch of stills in one step, or applied same transitions to this stills… does copy/paste attributes works?? Do a try!
    The work around I have found to your quest is to make the transition you want as default and then change the default setting to your taste and applied then (this for many stills or clips; not worth for occasional use)
    Maybe in future releases we will get the most of standard things. Just the developers need to read our concerns more closely.
