Activity Forums Apple Final Cut Pro Legacy Is there a way to clear the Batch Capture Bin?
  • Is there a way to clear the Batch Capture Bin?
    Posted by Brian Pitt on January 27, 2009 at 3:12 pm
    I’ve been having this problem for a few weeks now. Every time I log a couple of clips and go to capture them, FCP is seeing WAY more clips that need to be captured from multiple reels. I’m guessing that these are clips from previous projects.
    Is there a way to clear this list?
    Brian
    Tom Matthies replied 17 years, 7 months ago 3 Members · 2 Replies
  • Dennis Leppell
    January 27, 2009 at 4:01 pm
    I’ve had that happen before, but it was with version 5.04…don’t know what i did, but there’s two things I can think to try.
    1. Open FCP by double clicking a project file, rather than open via the application menu or taskbar. This kind gives what I’d call a ‘soft’ preferences reset. When you open FCP via application menu, it opens all the projects you had open the last time it ran, holding onto any extraneous data. Opening just a project file does just that, and nothing else.
    2. at the top of the batch capture window when it first comes up, the one that asks what format you want to capture everything with….The top drop box should read “capture selected items”. If you get a dialogue saying along the lines as there’s other associated media, do you want to capture it, say no.
  • Tom Matthies
    January 27, 2009 at 6:21 pm
    Try to make separate bins within your Project window rather than just having the Project window be the “Logging Bin”. In other words, make a new bin for your footage within the project window, make that new bin your Logging Bin and batch capture from that bin. That should eliminate FCP from wanting to capture everything in your entire project window.
    Also, Quit your project(s) BEFORE Quitting FCP to stop it from opening up the last project(s) you were working on when you launch the application. I always launch FCP from the Project itself and rarely by just launching FCP by itself.
    Tom
