Activity Forums Adobe After Effects Is there a way to automatically mute pieces of a clip that have been time remapped?
  • Is there a way to automatically mute pieces of a clip that have been time remapped?
    Posted by David Bernal on April 1, 2020 at 3:08 am
    So I do a lot of time remapping on montage clips. What I’ve been doing this whole time is remapping it then muting the audio by adding an audio keyframe right before the remap then one frame later lowering it to lowest volume and then when the remap is over bringing it back to 0 db.
    What I’m looking for is a way for After Effects to automatically mute audio that has been time remapped because it is very tedious doing this for every single clip.
    Graham Quince replied 6 years, 4 months ago 3 Members · 2 Replies
  • Darby Edelen
    April 3, 2020 at 6:08 pm
    You’d need an expression on the audio levels. Something like this:
    min = -64;
    transition = 0.1;
    s = Math.abs(timeRemap.speed - 1);
    linear(s, 0, Math.max(0.001, transition), [value, value], [min, min]);
    This should lower the audio levels from the keyframed values to -64 dB as the speed of the timeRemap property changes from 1 to 0.9 or 1.1.
    You can change the target audio level by changing the ‘min’ variable in the expression. If you want to make the drop in volume less sudden you’d increase the value of the ‘transition’ variable. If you want it more sudden you can decrease it.
    I haven’t tested this expression, writing from memory on my mobile so let me know if anything doesn’t work.
    Darby Edelen
  • Graham Quince
    April 10, 2020 at 2:22 pm
    I love that. Such a neat solution.
    http://www.YouTube.com/ShiveringCactus – Free FX for amateur films
    https://shiveringcactus.wordpress.com/ – FX blog
