Activity › Forums › Apple Final Cut Pro Legacy › Is there a way to apply the time code filter to an entire bin of timelines?
  • Is there a way to apply the time code filter to an entire bin of timelines?
    Posted by Michael Escher on May 2, 2008 at 2:05 am
    The title of this post pretty much says it all. I want to apply a time code burn filter to a bunch of timelines so I can do a batch low res export for the client to see the clips and make selections. Anyone know how to apply filters to multiple timelines at a time?
    Thanks again for all the help, now and in the future!
    Best,
    Michael Escher
    Los Angeles, CA, USA, Earth
    Tom Wolsky replied 18 years, 5 months ago 5 Members · 5 Replies
  • Carsten Orlt
    May 2, 2008 at 2:17 am
    only to multiple clips in a timeline.
    either make a favourite fx from your prefered TC reader setting and select all clips and then choose this favourite
    or
    apply to the first clips, copy, select all other clips and paste attributes – filter only
    if you done this on the first seq you only have to load the other seq’s and select all – paste attributes – filter only
  • Kevin Monahan
    May 2, 2008 at 2:32 am
    Use Compressor, not FCP for this. It has a time code filter and batch processing capabilities.
    If you must use FCP, you would have to nest all the sequences one by one, then apply the tc reader filter and then you can render them all by selecting them all and typing option + R as well.
    Good luck.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Michael Escher
    May 2, 2008 at 2:54 am
    Good to know Kevin. Thanks.
    Mike E.
  • Lu Nelson
    May 3, 2008 at 12:28 pm
    Kevin’s suggestion is perhaps simplest — to use Compressor;
    otherwise you could nest each one inside another sequence and apply the TCG filter to them one by one. Then you could batch export the containing sequences. This is a bit of handwork, but if you keep the containing sequences (let’s call them “Export Sequences”) around, you can always use them with the Batch Export tool to run export of the latest versions.
    Lu Nelson
    Berlin, Germany
  • Tom Wolsky
    May 3, 2008 at 1:43 pm
    How exactly are you exporting? Recent versions of QuickTime will display timecode in the player and there is no need for a TC overlay covering some of the picture.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
