Activity Forums Adobe After Effects Is there a way to adjust keylight to key out only a certain luminance value?
  • Is there a way to adjust keylight to key out only a certain luminance value?
    Posted by Andreas Sizynski on May 16, 2012 at 3:02 am
    Hey guys, I have a scene I am working on that has elements of green in the foreground, and a green screen in the back. I plan on evenly lighting the green screen, but there is some green in the actual set. The green screen is in the frame, but largely appears above the set, the set composition is of largely greys but there are prominent green bits too.
    I could just rotoscope, but is there a way to just make keylight stick with a luminance value for the key color?
    An Artist interested in the past, stuck in the present.
    Jeff Brown replied 14 years, 3 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    May 16, 2012 at 3:40 am
    Either a garbage matte or a hold-out matte is used when trying to de-limit the area of a key. Using luminance values is inherently what color keying works with.
    If you can post an image or a video directly onto the COW< then folks can provide an even more conclusive solution.
    Cheers
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Jeff Brown
    May 16, 2012 at 3:26 pm
    Have you considered using a blue-screen background?
