Activity › Forums › Adobe Premiere Pro › Is there a way to add drop shadow to keyed figure?
  • Is there a way to add drop shadow to keyed figure?
    Posted by Dragos on June 26, 2011 at 4:22 am
    I have a person I keyed out against a greenscreen background using ultrakey. I was hoping to add a drop shadow to separate him from the background plate I have him in front of. However, when I add a drop shadow it applies it to the full frame and not the alpha I’ve keyed out. Is there a way to have the shadow respond to the key or will it always respond to the full frame?
    I am exporting this as an flv for a website, so I imagine I may be able to mimic something in flash if absolutely necessary, but I’d like to avoid it if I can.
    Dragos replied 15 years, 3 months ago 5 Members · 7 Replies
  • 7 Replies
  • Dexter Andrada
    June 26, 2011 at 4:43 am
    What did you do to bring in the drop shadow? Video effects under Perspective?
  • Dragos
    June 26, 2011 at 4:47 am
    That’s what I tried so far. Is there another way? I’ve always edited in FCP, but I decided to use Premiere on this since it has a superior keyer.
    Dragzz
  • Daniel Mcclintock
    June 26, 2011 at 5:37 am
    Matt,
    double-check two things…
    1) In the Effects Control Panel make sure the Drop Shadow effect is below the Ultra Key filter. Premiere and After Effects apply their effects from the top down.
    2) Also make sure Ultra Key’s output has been reset to Composite.
    I hope that works for you.
    Sometimes life needs a Cmd-Z!
  • Jon Barrie
    June 26, 2011 at 10:38 am
    Hi Matt,
    I just tested the keyer with a drop shadow under the keyer in the list of effects and it works as expected.
    I don’t know why it would be behaving weirdly on your end? Do you have a “hacked” MPE GPU card using the Hardware MPE?
    Otherwise try to nest the clip and add the shadow to the nest? You can right click on the clip and select Nest from the list for it to replace the clip in the timeline with the nested version.
    – JB
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Ann Bens
    June 26, 2011 at 10:48 am
    Drop the shadow to the keyed footage and turn up the opacity.
  • Dragos
    June 26, 2011 at 3:04 pm
    No, it’s definitely not hacked. I’m running on a mac with a high end card and legal software. I’ll try what you said and see if it gives me a better result. I tried changing the drop shadow to red, and the entire frame gets a drop shadow, not the individual person who has had a green screen key applied to him.
    Dragzz
  • Dragos
    June 26, 2011 at 3:19 pm
    Stacking order was the issue. Thanks for the help!
    Dragzz
