Activity Forums Maxon Cinema 4D Is there a way blend 2 C-motion clips?
  • Is there a way blend 2 C-motion clips?
    Posted by Eddy Rose on March 23, 2012 at 6:32 pm
    Let’s say I have two C Motion clips, one to walk and one to jump. Is there a way to blend them together like with motion clips?
    Is there even a way to turn down the overall strength of a C Motion clip besides keyframing all the individual actions to zero?
    I understand you can turn them into motion clips,, but that’s a godawful pain when you’re using the advanced biped setup. You either have to live with a shitload of keyframes (it records EVERY frame of EVERY object in the hierarchy) or tediously uncheck the items that aren’t moving in the “Add Motion Clip” menu. Either way has given me alot of problems when I try to stretch or loop the clip.
    Eddy Rose replied 14 years, 6 months ago 2 Members · 2 Replies
  • Brian Jones
    March 24, 2012 at 7:47 pm
    check out https://www.cineversity.com/live and click on the Archives tab. They did CMotion twice (at the bottom) and I think I remember them covering blending.
  • Eddy Rose
    March 24, 2012 at 8:34 pm
    Already watched it. They don’t cover blending only converting to motion clips.
