Activity Forums Apple Final Cut Pro Legacy Is there a quick way to make all clips a specified length and apply a transition
  • Is there a quick way to make all clips a specified length and apply a transition
    Posted by Max Huggett on July 23, 2009 at 12:17 am
    Hi people
    I have stack of graphic overlays, that i would like to make 6 seconds in length. Is there an easy way to trim them so that there are this length.
    Furthermore, i would like them all to have a 10 frame dissolve/fade at the end of each clip. Can this be done in one go also, or is this an item by item case by dragging on the transition to the end of each clip.
    Thanks for any assistance.
    Max
    Max Huggett replied 17 years, 2 months ago 2 Members · 2 Replies
  • Josh Olenslager
    July 23, 2009 at 2:44 am
    Max,
    you can import all of the graphics in at a six second length if you go to user preferences and change the import still length to six seconds. (Sorry not in front of my system right now, so don’t know exactly what it’s called, but it’s right there in user prefs.) As for the fade, I’m not sure if there is a function to add to multiple clips at once, but you can create a 10 frame fade and set it as your favorite then roll through a pretty quick copy paste at the tail of each graphic.
    Best
    Josh
    Digital Media, Thought Equity Motion
  • Max Huggett
    July 23, 2009 at 4:11 am
    Thanks Josh, but all my graphics are rendered to a single file (11 mins long).
    In my edit, I have just gone through that file and found each inpoint and quickly tried to take 6 seconds of each 15sec graphic. So on my timeline, these graphics are all between 5 and 7 seconds, and i just want to tidy them up by making them all 6 seconds.
    m.
