Activity › Forums › Adobe Premiere Pro › Is there a quick way to change the background with a white screen?
  • Is there a quick way to change the background with a white screen?
    Posted by Ozzy Baines on January 24, 2013 at 9:28 pm
    I shot interviews in front of a white background, and I want to a change the background to a photograph. It was easy to do it with the interviews that were shot in front of a green background. I just used ultra key and changed the background to the photograph that I wanted. Is there a way to do this with a white background as well?
    Angelo Lorenzo replied 13 years, 8 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    January 24, 2013 at 10:20 pm
    Use the Luma Key effect, or you can use Ultra Key and just select your white.
    Luma keys are notoriously messy. You may have better results using After Effects and the rotobrush to create a clean cutout (good edge definition should make this rather easy) rather than using a keyer.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
