Activity › Forums › Adobe After Effects › Is there a problem with CS3 and 2008 Mac Pros ??
Posted by Brian Charles on February 26, 2008 at 2:44 pmSince I upgraded to from a 4 core a new Mac Pro 8 core, After Effects CS3 crashes more frequently.
I’ve turned OpenGL off, tried with multiprocessing enabled and disabled, turned off Nucleo and every other option I can think of.
I note a few other posts that report weird behavior on these machines.
As this is also my first foray into Leopard, I’m not sure whether this is an OS or hardware issue.
Anyone else??
Darby Edelen replied 18 years, 7 months ago 4 Members · 7 Replies -
Steve Roberts
February 26, 2008 at 3:10 pmCS3 is fine on my 8-core, OS10.4.11.
Leopard (or QT 7.4 if you have it) may be the problem. Have you upgraded to AE 8.0.2?
Darby Edelen
February 26, 2008 at 5:01 pmWe just set up a 2008 Mac Pro at work with CS3. So I’ll definitely let you know if we experience any problems. I will say that prior to this I was using CS3 on my first rev Mac Pro under Leopard/QT 7.4.1 and not having any more trouble (actually less) than my coworker running it on his Mac Pro under Tiger/QT 7.3.?
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA -
Brian Charles
February 26, 2008 at 6:12 pmHmmm. Sounds like more troubleshooting for me.
I was running on first gen Mac Pro Quad using 10.4.1 before with no issues.
Thank you both for the replies. I do have Nucleo which I find indispensable. Perhaps I should chuck it.
I’ve repaired permissions, done Onyx cache cleaning etc. Next I’ll light some incense and wave a dead chicken over the keyboard…
Darby Edelen
February 26, 2008 at 6:34 pm[Brian Charles] “Next I’ll light some incense and wave a dead chicken over the keyboard…”
Next?! You should’ve done that first! (;
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA -
Itamar Kool
February 26, 2008 at 8:51 pmI disabled Nucleo Pro 2. I found that AE is much more stable since then
Kool En De Anderen
MAC Pro 8 core/Kona LHe/Apple FCS 2/Adobe PPCS3/Huge fibrechannel
http://www.koolendeanderen.nl -
Brian Charles
February 27, 2008 at 2:27 amWaving the dead chicken over the keyboard produced no discernible results however removing Nucleo Pro from the Plug ins directory did.
I’m not certain where the conflict lies but I haven’t crashed once since removing Nucleo.
Darby Edelen
February 27, 2008 at 8:41 pm[Brian Charles] “I’m not certain where the conflict lies but I haven’t crashed once since removing Nucleo.”
I’ve seen Nucleo do some weird things to systems… I don’t know exactly how it messes things up, and it only seems to do it occasionally, but it’s enough to warrant not installing it (in my opinion) as it doesn’t improve my workflow much.
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA
