Activity › Forums › Adobe After Effects › Is there a plugin in AE that does this?
Posted by Christian Vilderman on December 15, 2015 at 3:11 pmChristian Vilderman replied 10 years, 9 months ago 2 Members · 2 Replies -
John Cuevas
December 15, 2015 at 3:17 pmNo, you need to manually do it that. If it’s something you are doing a lot. You probably could set up your video in a “Source precomp”, move that precomp into new a comp(s) and do all the work for you final. Then when just drop a new video into your “Source Precomp” and render then next one.
Johnny Cuevas, Editor
ThinkCK“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb.
