Activity Forums Panasonic Cameras Is there a PCMCIA to USB 2.0 reader???
  • Is there a PCMCIA to USB 2.0 reader???
    Posted by Carlos Prio on January 27, 2006 at 12:36 am
    Is there a PCMCIA to USB 2.0 reader available by any vendor???
    Carlos Prio
    field dominance
    prio(at)fielddominance.com
    305/971-7037 ext. 208
    cell. 305/785-7746
    Miami, FL
    G5 Dual 2.0 w/ 2.5 gigs of ram, 160hd
    OSX 10.4.3
    FCP HD 5.0.4
    Lacie 320 & 1T d2 extremes
    BMD HD w/ Multibridge HD
    Cinema Display
    100a, fx1, hc-1, and waiting for the HVX200
    Barry Green replied 20 years, 8 months ago 6 Members · 7 Replies
  • 7 Replies
  • David S.
    January 27, 2006 at 2:20 am
    If you are talking about a p2 card reader to USB 2, none of them being currently offered that are 32-bit, which is the requirement.
    PCI PC card readers are 32-bit, but then they obviously won’t work with a laptop.
    David S.
  • Carlos Prio
    January 27, 2006 at 12:03 pm
    The application is a single cheap over the counter reader (a la SD/CFcard reader) that you can plug into a G5.
    I have seen some cheap China stuff… any confirmations???
    Prio
    Carlos Prio
    field dominance
    cell. 305/785-7746
    Miami, FL
    OSX 10.4.3
    FCP HD 5.0.4
    Cinema Display
  • Jim
    January 27, 2006 at 2:20 pm
    In the same vein as the above question, with the new Mac laptops (Macbook Pro) having only an Express 3/4 card and not the slot that will fit the P2 card. If we what to dump the P2 card content to the new Mac laptops we will need some sort of Express 3/4,USB or Firewire I/O to Pcmcia card reader. Do such adapters exist, and if so, is the throughput speed fast enough for efficient workflow?
  • Ed Dooley
    January 27, 2006 at 4:44 pm
    A number of companies have announced various Express Slot34 cards (unfortunately, some cards so far, like FW800 cards, are 54
    cards, the bigger sibling. My guess is that within 6 months there’ll be SATAII 34 cards.
    Ed
    Memory card readers: https://www.akihabaranews.com/en/news-10957-Memory%20card%20reader%20for%20ExpressCard.html
    https://www.engadget.com/2006/01/11/y-e-data-announces-expresscard-34-media-reader/
    [Jim Cunningham] “In the same vein as the above question, with the new Mac laptops (Macbook Pro) having only an Express 3/4 card and not the slot that will fit the P2 card. If we what to dump the P2 card content to the new Mac laptops we will need some sort of Express 3/4,USB or Firewire I/O to Pcmcia card reader. Do such adapters exist, and if so, is the throughput speed fast enough for efficient workflow?
  • David S.
    January 27, 2006 at 7:27 pm
    [reelestates] “The application is a single cheap over the counter reader (a la SD/CFcard reader) that you can plug into a G5.”
    To read P2 cards, or SD or CF cards?
    You can get one of the latter at most office supply stores.
    A USB reader to read p2 cards has to be 32-bit. I’ve not found one.
    David S.
  • Bo Skelmose
    January 30, 2006 at 9:48 pm
    I use a reader from kingston for my Fostex FR-2 audiorecorder – dont know if it can read p2 but why not ?
    Found this link.
    https://www.superwarehouse.com/Kingston_USB_PC_Card_Reader/FCR-HS2_ATA/ps/455939
  • Barry Green
    January 31, 2006 at 12:01 am
    [Skelmose TV] “dont know if it can read p2 but why not ?”
    Because if it can’t, you may not be able to get your card out of it.
    16-bit PCMCIA has a smooth connector. 32-bit PCMCIA/CardBus adds raised dots on the connector; designed to prevent you from putting a 32-bit card in a 16-bit reader. If you do, and you force it in, you won’t be able to get the card back out, at least not without destroying the reader. P2 requires a 32-bit reader, and that’s the device that we’ve been having trouble finding.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
