Activity Forums Apple Final Cut Pro Legacy Is there a magic bullet for 4:3 to 16:9 conversion?
  • Is there a magic bullet for 4:3 to 16:9 conversion?
    Posted by Bbinlosangeles on August 9, 2005 at 7:59 pm
    I’m trying to slip a 4:3 clip into an anamorphic 16:9 project filled with 16:9 clips. So far, the only thing I have figured out is that if I set my 4:3 clip to 133% scale and a 25 aspect ratio, it more or less fits the rest of the footage.
    EXCEPT that it’s now blurry and not as good a quality as at 100% scale (obviously).
    Am I doing something wrong? Is there some magic bullet I’m missing to make the 4:3 look as good on the canvas as the rest of my 16:9 clips?? Did I do something wrong with the aspect ratio, for instance?
    Graeme Nattress replied 21 years, 1 month ago 2 Members · 1 Reply
  • Graeme Nattress
    August 9, 2005 at 11:54 pm
    Check the results on a monitor, and it could look better, and make sure in FCP5 scaling is set to high quality.
    Because you’re throwing information away in the up-scaling, there’s little that can be done. I am working on an enhanced scaling solution, but it’s taking longer than I thought…..
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
