Activity › Forums › Adobe Premiere Pro › Is there a global normalize?
Posted by Eric Freeman on December 7, 2007 at 1:47 amIs there a global normalize function as opposed normalizing each audio clip one at a time? If not, is there another way around this?
I have a couple of hundred audio clips paid out on an audio track. Each audio clip has different levels, and I want to normalize each clip in order to create a consistent audio track level output. I’d rather avoid the tedium of selecting each clip, selecting audio gain, and pressing the “normalize” button.
Mattias Naan replied 18 years, 4 months ago 3 Members · 4 Replies -
Ross Bradshaw
December 7, 2007 at 12:50 pmIm affraid Eric that in all my time working on PP I have never found such a way (If you ever find a way please let me know). If I know that I am going to have a lot of audio clips in the end edit I normalise them as I go.
If this does not appeal to you then there are one or two ways around it (but even still they will take time). 1. If you put all your audio clips onto the same track you can go to your audio mixer and select your track, pull down the read tab and click the ‘write’ option. This will allow you to push the fader up and down, so you can normalise your audio by ear but be warned it is very time consuming and at times not a very exact science which leads me onto option 2(You will need to have the CS3 package however). Again put all your audio onto the same track and solo it. export a master comp of the audio and bring it back into your project. Add this master to a new track and sync it up (should not be too hard). When the audio is in sync right click on your master track and you will see an option to ‘Edit in Soundbooth’, here choose the ‘render and replace’ option. This will launch soundbooth. There are many normalising presets and filters in soundbooth that will do a much better job than PP. Again to get it perfect you should spend a bit of time on it (if your audio was recorded on the same device and time than it will be easier for you). I would recomend option 2 (depend on the version you use) or pay the price for a lesson learned and individually normalise.
Hope this was some help. Good luck
Take it easy -
Eric Freeman
December 7, 2007 at 5:30 pmThanks for you post Ross.
I have PP 2.0, so it sounds like I’m going to have to normalize each track. However, I will create a script in AutoHotKey, and I will be able to select a track, and then just press one button to normalize. This should make the process somewhat tolerable. AutoHotKey is pretty cool. I could post a AutoHotKey script if you like once I create it.
Ross Bradshaw
December 8, 2007 at 3:54 pmHows it going Eric?
Yeah that would be great if you could? Cheers man. I’ve heard about AutoHotKey but never got a chance to have a good old look at it.
Take it easy man and best of luck with the edit and script.
Mattias Naan
April 21, 2008 at 3:10 pmHi there,
I’m currently editing a daily TV-show in Premiere CS3 and I’m having the same trouble with having to normalize each audio track by “Right click > Audio Gain > Normalize > OK”…And it’s getting pretty time-consuming and of course annoying.
Eric, were you able to come up with a script for this task? I’m very new to AutoHotKey and I could really use some help.
Huge thanks in advance!
