Activity Forums VEGAS Pro Is there a function for “Select all until end”?
  • Is there a function for “Select all until end”?
    Posted by Adjul Gardner on June 15, 2014 at 9:13 pm
    I work with multi-track files (up to 200 or so) and I often want to select everything to the right of a certain file, for re-sizing and getting the right fade-times, and so on. Right now I’ve been doing it by hand, by double-clicking the vertical track scroller (to go into the mini-track view), and zooming out on the tracks all the way, and then pressing D until I get the square-selector, and dragging my mouse for 15 seconds down and to the right. I’m hoping there’s a shortcut I don’t know about, is there?
    Marcus
    Edward Troxel replied 12 years, 2 months ago 5 Members · 4 Replies
  • John Rofrano
    June 15, 2014 at 11:38 pm
    [Marcus Gardner] “I’m hoping there’s a shortcut I don’t know about, is there?”
    There is a selection tool on the tool bar and if you zoom way out on your project you can use the selection tool to select an entire area.
    There is also an inexpensive plug-in that will help. It’s the VASST Event Tools plug-in ($9.95 USD).
    You can select anything in any direction and a whole lot more (cuz’ that’s just what the selection tab does).
    In the interest of full disclosure, I’m the author of Event Tools and I’d be happy to answer any questions you may have about it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Aleksey Tarasov
    June 16, 2014 at 7:48 am
    To quickly select a group of events: Click the top left event, hold down Shift, and click the bottom right event.
  • David Shirey
    June 17, 2014 at 7:32 pm
    I’d recommend John’s solution. I’m still using the SelectEventsFromCursor script he wrote in 2004, which I assume is also included in that package? First thing I do every time I have to install Vegas is bind that script to Ctrl+w. Not sure why I picked W back then but it’s so engrained in my muscle memory I can’t go changing it now.
  • Edward Troxel
    June 18, 2014 at 4:22 pm
    SelectAllEventsAfterCursor.cs
    * This script will select all events after the cursor
    * Written By: Edward Troxel
    * Modified: 10-23-2007
    using System;
    using Sony.Vegas;
    public class EntryPoint
    Vegas myVegas;
    public void FromVegas(Vegas vegas)
    myVegas = vegas;
    foreach (Track track in myVegas.Project.Tracks)
    foreach(TrackEvent evnt in track.Events)
    evnt.Selected = false;
    if (evnt.Start >= myVegas.Cursor)
    evnt.Selected = true;
    using System;
    using Sony.Vegas;
    Vegas myVegas;
    myVegas = vegas;
    Edward Troxel
