Activity Forums Avid Media Composer is there a flash flv-file exporting plugin available for media composer
  • is there a flash flv-file exporting plugin available for media composer
    Posted by Sebastian Riezler on November 28, 2006 at 1:09 pm
    Hi there!
    Does anybody of you know if there is a plugin available for exporting flv-files from the avid media composer. the best would be if the export will proceed faster than realtime.
    we need our movies to be exported without going the way over quicktime movies.
    thanks in advance
    Riot
    Sebastian Riezler replied 19 years, 5 months ago 2 Members · 2 Replies
  • Dave Schweitzer
    November 28, 2006 at 9:39 pm
    Sorenson Squeeze comes to mind, I’ve got v.4.3 and it does FLVs via QT Ref.
    Also a quick google search brought up this:
    https://www.on2.com/downloads/flix-demo-software/
  • Sebastian Riezler
    November 30, 2006 at 5:28 pm
    thanks for your reply, but it wasn’t quite the thing i was looking for, because it works for nearly every NLE but AVID’s. why has always AVID the role of the special guy? it bores me.
    the sorensen thing is a quite good idea, but i thought it would be much cheaper to just buy plugins than one or more licenses of sorensen.
    i found a plugin from adobe, but it renders out in the H623 codec, which looks too crappy for our uses.
    the next thing is with realtime or faster export. not nearly in the reach of realtime.
    a 10sec sequence took 50sec to export.
    so i’m a little stuck now.
    Riot
